Siebel Product Administration Guide > Designing Products with Components > Process of Designing a Product with Components > Adding a Group of Products from Different Classes as ComponentsThe products you add to a relationship do not have to be from the same class. You can group products from several classes or products not assigned to a class into one relationship. This task is a step in Process of Designing a Product with Components. You do this by creating a relationship of domain type Class but without specifying a class. This allows you to select products from anywhere in the class system. You can do anything with this relationship that you can do with other class-type relationships such as creating resources, configuration rules, and links. CAUTION: This method of defining a relationship domain requires a search throughout the class system each time the product with components is instantiated. This can have an adverse impact on performance. Avoid using this method, if possible. To add groups of products from different classes
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
