| Siebel Product Administration Guide > Creating Custom Siebel Configurator User Interfaces > Tasks for Setting Up the Siebel Configurator HI User Interface > Using the Attribute Inline Display Control in the HI Siebel Configurator User Interface
 The Attribute Inline Display control allows you to display attributes of child products on the same Siebel Configurator selection page as the parent product. It is available only in the HI user interface.  The control is a form with attributes of the child product. You can click tabs at the top of the control to display forms for different child products.  For example, a parent product might be Mobile Package, a package of options for purchasing cell phone service. Child products might be Mobile Subscription Options, Price Plans, and Accessories. When the user displays the selection page for Mobile Package, the Attribute Inline Display Control has a series of tabs that the user can click to display the attributes for these child products.  To set up the Attribute Inline Display control
For the Parent Product from which users can choose a Child Product:
Navigate to the Administration - Product screen, then the Product Definitions view and select the Customizable Product (for example, Mobile Package).
In the Versions list, click the Work Space version.
Click the User Interface view tab.
Select the UI Group where the child product is referenced (for example, Subscription Details).
Select eCfgControlComboAddPriceAttribGridJS.swtas the Group item theme.For the Group name defined earlier (for example, Subscription Details), add new User Property named MultiChildrenPort, and provide the relationship name as its value (for example, Mobile Subscription Options).
For the child product whose attributes will be shown and selected:
Navigate to the Administration - Product screen, then the Product Definitions view and select the Customizable Product (for example, Mobile Subscription).
Navigate to User Interface view.
Create a new UI Group, and complete the fields with the values described in the following table.
    | Group Name | Grandchild Attr |
    | Group Theme | Standard Group Theme JS |
    | Sequence | 10 |
Add all the attributes that you want to show as Group Items in this new UI Group, for example, Activate Immediately, Activated.
Create a new root product UI Property and complete the fields with the values described in the following table.
    | Default Group | Grandchild Attr |
For an attributes that you specified earlier, such as Activate Immediately, create a new UI Property and complete the fields with the values described in the following table.
Create another new UI Property and complete the fields with the appropriate values, such as the values described in the following table.  NOTE:  The type is case sensitive and must be in all lower case. Other supported types are text and radio.For other attributes that you specified earlier, such as Activated, create a new UI Property and complete the fields with the values described in the following table.
Create another new UI Property and complete the fields with the appropriate values, such as the values described in the following table. Release a New Version of the product
Release the Parent Customizable Product.
