Siebel Product Administration Guide > Creating Custom Siebel Configurator User Interfaces > About Siebel Configurator UI GroupsGroups are the way you define what items appear on a selection page. Depending on the product theme, each group you define causes a separate selection page to be created. For example, you want all the hard disks in a product with components to appear on the same page. You do this by defining a group in the User Interface view and then adding the Hard Disks relationship to this group. If you selected a tab type product theme, the hard disks display as a selectable page tab. When the user clicks on the tab, a selection page displays containing only the hard disks. The User Interface view lets you create groups that contain relationships, attributes, resources, or links. When you create a group, you can choose a group style. The group style defines the details of how a group will display. |
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
