Siebel Product Administration Guide > Managing Products with Components > Controlling How Products with Components are ForecastWhen you add a component to a product with components, a check mark displays in the Forecastable field. This means the component is added to product forecasts when the product with components is included in a quote and the user updates the related opportunity. To prevent components from being added to product forecasts, remove the check mark from the component's Forecastable field. A Forecastable check box is also available in Quotes, then Line Items. This allows you to add or remove a product or component from product forecasts within individual quotes. |
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
