| Siebel Product Administration Guide > Multilingual Translations for Product Data >  Translating UI Property Values
 Use this procedure to translate the value of a UI Property. The property type must be type String.  To translate a UI property value
Navigate to the Administration - Product screen, then the Product Definitions view.
In the Products list, select and lock the desired customizable product.
In the Versions list, click the Work Space version.
Click the Properties view tab.
Select the UI property you want to translate.
From the Customizable Product menu, choose Translate UI Property.
A dialog box appears that displays the relationship name translations you have already created. In the dialog box, add a new record and complete the necessary fields, described in the following table.
    | Language | Displays the name of the language after you select the code. |
    | Code | Select a language code.  |
    | Description | Enter the translation of the description.  |  |
