| Siebel Product Administration Guide > Siebel Configurator Scripts > About Managing Siebel Configurator Scripts > Deleting Siebel Configurator Scripts
 After deleting a script, test the customizable product in validation mode to verify that the product works correctly.  To delete a script
Navigate to the Administration - Product screen.
Select and lock the desired product or product class.
Navigate to the Scripts view for the Work Space version.
In the Scripts list, select the script you want to delete.
In the Scripts list, click Delete.
Open the Scripts view list menu and click Validate.
This starts a configuration session. Verify that the customizable product functions correctly.
