Siebel Product Administration Guide > Siebel Configurator Scripts > About Product Names in Siebel Configurator ScriptsSeveral scripting methods have product name as an argument. Product name in this context means the name of a component product you have added from the product table to a customizable product. You must specify product names in a way that makes them unique. You do this by specifying the product name, vendor name, vendor location, and attribute values. Specify product names using the following syntax: {ProductName; VendorName; VendorLocation}; AttributeName1=Value1; AttributeName2=Value2; ... Observe the following guidelines when specifying product names:
Observe the following guideline when specifying the product path: do not use the sequence #1 inside the product path. This sequence is invalid. For example, the following product path does not work: |
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
