| Siebel Product Administration Guide > Smart Part Numbers for Products with Attributes > Process of Creating Predefined Smart Part Numbers > Creating a Part Number Generation Record
 First, create a part number generation record. This record names the part number generation method and specifies whether the method is dynamic or predefined.  This task is a step in Process of Creating Predefined Smart Part Numbers.
Navigate to the Administration - Products screen, then the Product Classes view.
In the Product Classes list, select the desired product class.
Click the link in the Smart Part Number field.
In the Part Number Definitions list, add a new record and complete the necessary fields, described in the following table.
    | Name | Enter a name for the part number generation method. |
    | Type | Select Predefined.  |  |
