Siebel Product Administration Guide > Smart Part Numbers for Products with Attributes > Roadmap for Creating Smart Part NumbersSmart part number provides the following methods for defining how part numbers are generated:
You define named smart part number methods on product classes. These methods use the attributes defined on the class to generate a part number. Only attributes with a list of values domain can be used to generate part numbers. When you assign a product to a class, you can select for it any of the smart part number methods that have been defined on the class. If you add or remove attributes on a class, or change the values for an attribute, these changes are not automatically propagated to the smart part number methods defined on the class. You must manually update each smart part number method with the changes. To create smart part numbers for products, perform the following tasks:
| Siebel Product Administration Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
