Table 53. Parameters of the Transaction Processor Server Component
Clean DX Files Iterations |
CleanFilesIter |
Optional |
Specifies how frequently the Transaction Processor server component deletes DX files from the docking\txnproc folder on the Siebel Server. The default value is 1 iteration, with a default of 60 seconds for each iteration, as set in the SleepTime parameter. |
Clean Transaction Iterations |
CleanTxnsIter |
Optional |
Specifies how frequently the Transaction Processor server component deletes transactions from the master transaction log table of the Siebel database. You specify this parameter as the number of iterations. The default value is 10. |
Maximum Reads per Iteration |
MaxRead |
Optional |
Specifies the maximum number of operations to read for each iteration. The default value is 0, which configures the Transaction Processor server component to read outstanding operations in the Master Transaction Log. |
Sleep Time |
SleepTime |
Optional |
Specifies the time, in seconds, to sleep between iterations. When the Transaction Processor server component wakes up, it processes transactions. The default value is 60. |
TS Block Size |
TSBlockSize |
Optional |
Specifies the block size for the dobjinst.dbf visibility database, in bytes. The Transaction Processor server component stores data in blocks. This block size is different from the block size that the operating system uses. The default value is 4096 bytes. For help with modifying this parameter, see Getting Help from Oracle. |
TS Cache Size |
TSCacheSize |
Optional |
Specifies the cache size for the dobjinst.dbf visibility database, in kilobytes. The default value is 4096 kilobytes. For help with modifying this parameter, see Getting Help from Oracle. |
Write Compressed DX Files |
WriteCompressed |
Optional |
Specifies to write DX files in compressed format. The default value is FALSE. Leave this parameter at the default value. For help with modifying this parameter, see Getting Help from Oracle. |
