Table 20.	Siebel CRM z/OS Upgrade Files
    Phase Transferred to Host  |
    job0.txt  |
    JOB0  |
    ftp_stg  |
    Contains REXX code and panels  |
    All  |
    	SIEBEL.load.xmit	  |
    load.xmit	  |
    ftp_stg	  |
    Load modules  |
    All  |
    	sbllog.txt	   |
    SBLLOG.LOADFILE	  |
    ftp_stg	    |
    Initial log file entries  |
    All  |
    SIEBEL.sp.dbrmlib.xmit	  |
    sp.dbrmlib.xmit	  |
    ftp_stg	  |
    Dbrm modules  |
    All  |
    SIEBEL.sp.spddl.xmit  |
    	sp.spddl.xmit	  |
    ftp_stg  |
    Stored procedure DDL  |
    All  |
    job1.txt	  |
    VSTG0000  VSTG0000 is copied into one of the following VSTG* files on the z/OS host, depending on your upgrade path: VSTG0002 VSTG0020	VSTG0021		VSTG0022		VSTG0003 VSTG0005		VSTG0006		VSTG0040	VSTG0041	 VSTG0042  |
    ftp_stg  |
    Generic install.jcl and help panels  |
    All  |
    siebin01.jcl	  |
     	VSTG0001		 VSTG0001		 is copied into one of the following VSTG* files on the z/OS host, depending on your upgrade path: VSTG0011		 VSTG0030	 VSTG0031 VSTG0032	 	VSTG0012 VSTG0014 VSTG0015		 VSTG0050 VSTG0051 VSTG0052  |
    ftp_stg	  |
    Install.jcl specific to each upgrade path  |
    All  |
    siebproc.jcl	  |
    VSTG0070	  |
    ftp_stg	  |
    JCL PROC members  |
    All  |
    filelist.txt			  |
    VSTG0075	 	  |
    Pause #1  |
    List of files  |
    All  |
    synctab.jcl  |
    VSTG0085  |
    syncdd  |
    Table Synchronization  |
    All  |
    syncidx.sql  |
    VSTG0087  |
    syncdd  |
    Index Synchronization  |
    All  |
    schema.staging.db.sql  |
    VSTG0090  |
    ftp_stg  |
    Staging schema databases  |
    All  |
    schema.staging.tbsp.sql  |
    VSTG0091  |
    ftp_stg  |
    Staging schema table spaces  |
    All  |
    schema.staging.tbl.sql  |
    VSTG0092  |
    ftp_stg  |
    Staging schema tables  |
    All  |
    schema.staging.uind.sql  |
    VSTG0093  |
    ftp_stg  |
    Staging schema unique indexes  |
    All  |
    schema.staging.nuind.sql  |
    VSTG0094  |
    ftp_stg  |
    Staging schema NPIs  |
    All  |
    schema.staging.oind.sql  |
    VSTG0095  |
    ftp_stg  |
    Staging schema obsolete indexes  |
    All  |
    schema.staging.grt.sql  |
    VSTG0096  |
    ftp_stg  |
    Staging schema grants  |
    All  |
    schema.db.sql	  |
    VSTG0100	  |
    Pause#2	  |
    Target schema databases  |
    All  |
    schema.tbsp.sql	  |
    VSTG0101	  |
    Pause#2		  |
    Target schema table spaces		  |
    All  |
    schema.tbl.sql 	  |
    VSTG0102	  |
    Pause#2		  |
    Target schema tables  |
    All  |
    schema.grt.sql	  |
    VSTG0103	  |
    Pause#2		  |
    Target schema grants		  |
    All  |
    schema.uind.sql   |
    VSTG0104	  |
    Pause#2		  |
    Target schema unique indexes		  |
    All  |
    schema.nuind.sql   |
    VSTG0105	  |
    Pause#2	  |
    Target schema NPIs		  |
    All  |
    schema.oind.sql	  |
    VSTG0106	  |
    Pause#2	  |
    Target schema obsolete indexes  |
    All  |
    Not applicable    |
    VSTG1010 This file is created on the z/OS host. It contains CREATE INDEX statements extracted from VSTG0104 and VSTG0105.  |
    Not applicable  |
    Generates index REBUILD control statements for the target environment.  |
    All    |
    Not applicable    |
    VSTG1111 This file is dynamically built on the z/OS host.  |
    Not applicable  |
    Maintains a list of the additive changes that are applied to the staging database. This list is updated dynamically as changes are applied.  |
    All    |
    Not applicable    |
    VSTG1112 This file is dynamically built on the z/OS host.  |
    Not applicable  |
    Contains the additive changes applied to the staging database during the preupgrade phase.  |
    All    |
    scindx.sql  |
    VSTG0110  |
    Pause#3  |
    DDL for secondary indexes  |
    All  |
    tmptable.sql	  |
    VSTG0119  |
    Pause#2	  |
    Staging. Common TMPTABLES (tmptable.ctl)  |
    All  |
    tmptable.sql	  |
    VSTG0120		  |
    Pause#2	  |
    Target. Common TMPTABLES (tmptable.ctl)  |
    All  |
    tmptable1.sql	  |
    VSTG0121	 	  |
    ftp_stg  |
    Staging.  Logging for Unload jobs and TMPTBL_ADDR table (no storage.ctl file)  |
    All  |
    tmptable2.sql	  |
    VSTG0122	 	  |
    ftp_stg  |
    Target.  Logging for Unload jobs and TMPTBL_ADDR table (no storage.ctl file)  |
    All  |
    drop_view.sql	  |
    VSTG0130		  |
    ftp_stg		  |
    Apply drop view before Nonadditive  |
    All  |
    ddlview_sql  |
    VSTG0131  |
    ftp_stg  |
    Apply create view after Nonadditive  |
    All  |
    siebel.translate.iconv	  |
    VSTG0150		  |
    Pause #1  |
    Program to convert code pages for each language  |
    All  |
    pregen.txt	  |
    VSTG0200	 	  |
    ftp_stg  |
    JCL (genclobf, gentrgd, geneimd)  |
    All  |
    pret.jcl	  |
    VSTG0210		  |
    Pause #1  |
    PRET SQL  |
    All  |
    pret_prod.jcl	  |
    VSTG0211		  |
    Pause #1  |
    PRET JCL  |
    All  |
    pret_sia_prod.jcl	  |
    VSTG0221		  |
    Pause #1  |
    PRETFINS JCL  |
    SIA753, SIA77, SIA78, SIA80  |
    unload.ldc	  |
    VSTG0300		  |
    Pause #2	  |
    Unload control cards  |
    All  |
    load.ldc	  |
    VSTG0310		  |
    Pause #2	  |
    Load control cards  |
    All  |
    preschm.jcl	  |
    VSTG0400		  |
    Pause #1  |
    PRESCHM SQL  |
    All  |
    preschm_prod.jcl	  |
    VSTG0401		  |
    Pause #1	  |
    PRESCHM JCL  |
    All  |
    preschm_sia.jcl  |
    VSTG0410  |
    Pause #1  |
    PRESCHMF SQL  |
    preschm_sia_prod.jcl  |
    VSTG0411  |
    Pause #1  |
    PRESCHMF JCL  |
    upg_iss.jcl	  |
    VSTG0600		  |
    Pause #1	  |
    UPGISS JCL  |
    All  |
    upg_iss_prod.jcl	  |
    VSTG0601		  |
    Pause #1  |
    UPGISS SQL  |
    All  |
    gen_primary1.jcl	  |
    VSTG0700		  |
    Pause #1	  |
    Gen Primary part 1 - SQL  |
    All  |
    gen_primary1_prod.jcl	  |
    VSTG0701		  |
    Pause #1	  |
    Gen Primary part 1 - JCL  |
    All  |
    gen_primary2.jcl	  |
    VSTG0702		  |
    Pause #1  |
    Gen Primary part 2 - SQL  |
    All  |
    gen_primary2_prod.jcl	  |
    VSTG0703  |
    		Pause #1  |
    Gen Primary part 2 - JCL  |
    All  |
    gen_primary3.jcl	  |
    VSTG0704		  |
    Pause #1  |
    Gen Primary part 3 - SQL  |
    	All  |
    gen_primary3_prod.jcl	  |
    VSTG0705		  |
    Pause #1  |
    Gen Primary part 3 - JCL  |
    All  |
    gen_primary4.jcl	  |
    VSTG0706		  |
    Pause #1  |
    Gen Primary part 4 - SQL  |
    All  |
    gen_primary4_prod.jcl	  |
    VSTG0707  |
    Pause #1  |
    Gen Primary part 4 - JCL  |
    All  |
    hhmignot.sql	  |
    VSTG0850  |
    Pause #1  |
    Household  |
    hhmigpop.sql	  |
    VSTG0851 	  |
    Pause #1  |
    Household  |
    household_mig_Fins.jcl	  |
    VSTG0852	   |
    Pause #1	  |
    Household  |
    household_mig_Fins_prod.jcl	  |
    VSTG0853	   |
    Pause #1  |
    Household  |
    rpt_dup_addr_rowids.sql   |
    	VSTG0861  |
    ftp_stg  |
    Gen Dup Addr Report SQL  |
    All  |
    rpt_dup_addr_names.sql 	  |
    VSTG0860	  |
    ftp_stg	  |
    All  |
    schema.additive.sql  |
    VSTG1000  |
    Pause #1  |
    Staging additive changes  |
    All  |
    Not applicable  |
    VSTG1001 This file is a copy of VSTG1000; it is created on the z/OS host.  |
    Not applicable  |
    Target additive changes  |
    All  |
