Siebel Database Upgrade Guide for DB2 for z/OS > Running the Database Configuration Wizard to Perform Upgrade Tasks > Starting the Siebel Upgrade Wizard > Stopping the Siebel Upgrade WizardDo not stop the Upgrade Wizard unless you are confident that an error has occurred, and the Upgrade Wizard or a utility it has called is hung. Some SQL commands issued by the Upgrade Wizard or by its utilities can take considerable time to complete. If you are unsure whether or not the Upgrade Wizard has stopped responding, create a service request (SR) on My Oracle Support. You can log service requests by accessing My Oracle Support (Service Request tab), or by using your existing phone support numbers to contact Oracle Global Customer Support. Stopping the Upgrade Wizard can have varying effects on the RDBMS. Before restarting the Upgrade Wizard, review the upgrade log files. Run SQL commands as required to resolve errors found in the logs. The following procedure describes how to stop the Upgrade Wizard in a Windows environment. To stop the Upgrade Wizard under Windows
The following procedure describes how to stop the Upgrade Wizard in a UNIX environment. To stop the Upgrade Wizard under UNIX
After the processes terminate, there might be a delay while the RDBMS executes SQL commands that have already been issued. |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
