Siebel Database Upgrade Guide for DB2 for z/OS > Running the Database Configuration Wizard to Perform Upgrade Tasks > Upgrading the Repository and Importing Seed DataEnvironments: All environments. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. After you have created the staging database, generated the upgrade files, and upgraded the target database, you must upgrade the repository and import seed data. Run the Database Configuration Wizard to upgrade the repository and import seed data as described in the following procedure. To upgrade the repository and import seed data
NOTE: The process of importing seed data and upgrading the repository can take several hours. Restarting the Seed Data Import and Repository UpgradeIf the Upgrade Wizard stops responding during the Repository Data Upgrade process, restart the process using the following procedure. To restart the repository upgrade and seed data import process
NOTE: To improve the repository upgrade performance, execute the REORG utility on the tables listed in About Reorganizing Tables Before the Repository Merge before performing the repository merge. |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
