Siebel Database Upgrade Guide for DB2 for z/OS > Performing the Siebel Incremental Repository Merge > Performing the Incremental Repository Merge > Executing the Incremental Repository Merge Under UNIXUse the following task to execute the incremental repository merge if you are running the Siebel Database Configuration Wizard on UNIX, or if Siebel Tools is installed on UNIX. Incremental repository merge is started automatically under Windows, but under UNIX you must initiate the process manually. You begin executing the incremental merge when the Upgrade Wizard pauses and notifies you to execute the manual merge. To execute incremental repository merge under UNIX
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
