Siebel Database Upgrade Guide for DB2 for z/OS > Performing the Siebel Incremental Repository Merge > Editing the Siebel Tools Configuration File After the Development Environment MergeAfter you have completed the upgphys process to upgrade the custom database schema in the development environment (see Step 7), then edit the Siebel Tools configuration file as described in this topic. This task is a step in Process of Performing an Incremental Upgrade of the Siebel Database from Siebel CRM Version 8.1.1.x. NOTE: You set the prefix back to X_ from the changed value of SBL_ to enable you to create your own custom symbolic strings after the merge. |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
