Siebel Database Upgrade Guide for DB2 for z/OS > Upgrading the Target Database > Dropping Partitioned EIM TablesDuring the target database upgrade, EIM tables are dropped after additive changes are applied to the database and are later re-created when the nonadditive schema changes are applied to the database. When a partitioned EIM table is dropped, however, the table space is also dropped. Because table space creation is considered an additive change, the upgrade attempts to create EIM table spaces for partitioned EIM tables when other additive changes are applied to the target database, that is, before the partitioned EIM tables and related table spaces have been dropped. To avoid processing errors during the target database upgrade, therefore, you must manually change the sequence in which partitioned EIM tables are dropped. Drop partitioned EIM tables before you apply additive schema changes to the target database. The following procedure describes how to change the sequence in which partitioned EIM tables are dropped. To drop partitioned EIM tables
Sample Code for Generating a List of Table Spaces to DropThe following sample SQL code can be used to generate a list of the table spaces that must be dropped before applying additive schema changes. The table spaces can be determined with the following SQL: -- The following is an example of a list of tables generated by running the query in the sample code: DROP TABLESPACE D0020004.H0004000 / DROP TABLESPACE D0020010.H0010000 / DROP TABLESPACE D0020031.H0031000 / DROP TABLESPACE D0020065.H0065000 / DROP TABLESPACE D0020102.H0102000 / DROP TABLESPACE D0020194.H0194000 / |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
