Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using a New Object Wizard
A new object wizard is a feature that you can use that guides you through the steps of creating a new object. It prompts you to configure the properties and objects that Siebel Tools requires according to the object type that you are creating. You can use a new object wizard to create the following objects:
- General object. For example, a business component, table, view, or applet method menu item.
- Applet object. For example, a list applet, form applet, MVG Applet, or chart applet.
- EAI object. For example, an integration object.
- Task object. For example, a task, task applet, task view, or transient business component.
For more information about how to use a wizard for a particular object type, see Configuring Siebel Business Applications. To use a new object wizard
- Do one of the following:
- Choose a wizard.
