Bookshelf Home
Contents
Index
PDF
Using Siebel Tools
Using Siebel Tools
Roadmap for Setting Up and Using Siebel Tools
To set up and use Siebel Tools, do the following tasks:
Process of Setting Up the Development Environment
Specifying the Web Template Editor
Getting All Projects from the Server Repository
Allowing Object Locking for a Project
Checking Out Projects from the Server Repository
Creating, Modifying, Copying, Validating, and Deleting Objects
Checking In Projects or Objects to the Server Repository
Compiling Your Modifications
Testing and Troubleshooting Your Modifications
Exporting Objects to an Archive
Using Siebel Tools
Copyright © 2014, Oracle and/or its affiliates. All rights reserved.
Legal Notices.
