Using Siebel Tools > Using Siebel Tools > Using Editors in Siebel Tools >
Using a Script Editor
If you cannot use declarative configuration to meet your requirements, then you can use the Server Script Editor and the Browser Script Editor in Siebel Tools to create a script. You use these editors to add a script to a Siebel object. You can use the following types of script:
- Siebel VB
- Siebel eScript
- Browser Script
For information about declarative configuration, see Overview of Using Siebel Tools. For information about scripting, see Using Siebel Script Editors.
