Siebel VB Language Reference > Using Siebel VB > About Data Types >
Type Characters
Siebel VB can use a special character as the suffix of the name of a function, variable, or constant. This character identifies the data type of the variable or function. It is a declaration.
Table 5 lists the characters you can use as a suffix.
Table 5. Characters You Can Use as a Suffix
Data Type
Suffix
Dynamic String
Integer
Long Integer
Single-precision floating-point
Double-precision floating-point
Currency, exact fixed point
Siebel VB Language Reference Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
