Siebel VB Language Reference > Using Siebel VB > About Error Handling >
Error Code and Error Text for Siebel VB Errors
Table 23 lists the run-time errors that Siebel VB returns. The On Error statement can handle these errors. The Err function can query the error code and the Error function can query the error text. For more information, see the following topics:
Table 23. Run-Time Errors That Siebel VB Returns
Error Code
Error Text
     5
Illegal function call
     6
Overflow
     7
Out of memory
     9
Subscript out of range
     10
Duplicate definition
     11
Division by zero
     13
Type Mismatch
     14
Out of string space
     19
No Resume
     20
Resume without error
     28
Out of stack space
     35
Sub or Function not defined
     48
Error in loading DLL
     52
Bad file name or number
     53
File not found
     54
Bad file mode
    55
File already open
    58
File already exists
    61
Disk full
    62
Input past end of file
    63
Bad record number
    64
Bad file name
    68
Device unavailable
    70
Permission denied
    71
Disk not ready
    74
Can't rename with different drive
    75
Path/File access error
    76
Path not found
    91
Object variable set to Nothing
    93
Invalid pattern
    94
Illegal use of NULL
    102
Command failed
    429
Object creation failed
    438
No such property or method
    439
Argument type mismatch
    440
Object error
    901
Input buffer is larger than 64K
    902
Operating system error
    903
External procedure not found
    904
Global variable type mismatch
    905
User-defined type mismatch
    906
External procedure interface mismatch
    907
Pushbutton required
    908
Module has no MAIN
    910
Dialog box not declared
Siebel VB Language Reference Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
