Siebel VB Language Reference > Using Siebel VB > About Data Types >
Numeric Data Types That Siebel VB Uses
Table 3 describes the numeric data types that Siebel VB uses.
Table 3. Numeric Data Types That Siebel VB Uses
Type
Description
Smallest Value
Largest Value
Integer
2 byte integer
Negative 32,768.
Positive 32,767.
Long
4 byte integer
Negative 2,147,483,648.
Positive 2,147,483,647.
Single-Precision
4 byte floating-point number
Negative 3.402823e+38
0.0,
1.401298e-45.
Negative 1.401298e-45,
3.402823466e+38.
Double-Precision
8 byte floating-point number
Negative 1.797693134862315d+308,
0.0,
2.2250738585072014d-308.
Negative 4.94065645841247d-308,
1.797693134862315d+308.
Currency
8 byte number with a fixed decimal point
Negative 922,337,203,685,477.5808.
Positive 922,337,203,685,477.5807.
A numeric value is always signed.
You can write code that expresses an integer constant in the following ways:
  • Decimal. You can use the decimal representation to express a decimal constant.
  • Octal. You precede the constant with &O or with &o to express an octal value. For example, &o177.
  • Hexadecimal. You precede the constant with &H or with &h to express a hexadecimal value. For example, &H8001.
For more information, see Boolean Data Type.
Siebel VB Language Reference Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
