In this example, switch 2 is removed from switch 1.
SEFOS# configure terminal SEFOS(config)# router rip SEFOS(config-router)# network 10.0.0.1
SEFOS(config-router)# no neighbor 10.0.0.2 SEFOS(config-router)# end
In switch 1, you should be able to view the routes that are sent as RIP updates from both of the neighbor routers (switch 2 at 10.0.0.2 and switch 3 at 10.0.0.3).
