To make the PVRST+ module completely operational, you must configure the VLAN module. Before you configure VLAN as described in these sections, see VLAN Module to ensure that the configuration guidelines are satisfied.
The examples in this section use switch B (hostname TOR-1), port 0/1, and VLAN 10 and VLAN 20.
