- Enable
RIPng on the interfaces on SEFOS1.
SEFOS 1 SEFOS# configure terminal
SEFOS 1 SEFOS(config)# interface vlan 30
SEFOS 1 SEFOS(config-if)# ipv6 rip enable
SEFOS 1 SEFOS(config-if)# exit
SEFOS 1 SEFOS(config)# interface vlan 40
SEFOS 1 SEFOS(config)# interface vlan 50
- Enable RIPng on the interfaces
on SEFOS2.
SEFOS 2 SEFOS# configure terminal
SEFOS 2 SEFOS(config)# interface vlan 10
SEFOS 2 SEFOS(config-if)# ipv6 rip enable
SEFOS 2 SEFOS(config-if)# exit
SEFOS 2 SEFOS(config)# interface vlan 40
on SEFOS3.
SEFOS 3 SEFOS# configure terminal
SEFOS 3 SEFOS(config)# interface vlan 20
SEFOS 3 SEFOS(config-if)# ipv6 rip enable
SEFOS 3 SEFOS(config-if)# exit
SEFOS 3 SEFOS(config)# interface vlan 30
- Review the RIPng status on SEFOS1.
SEFOS 1 SEFOS# show ipv6 rip
RIP port 521, multicast-group ff02::9,Maximum paths is 16
Updates every 30 seconds; expire after 180SEFOS 1 SEFOS# show ipv6 rip database
Garbage Collect after 120 secondsRIP local RIB 1111::/112, metric 2, ripng vlan40/fe80::214:4fff:fe6c:630f, expires in 180 secs 2222::/112, metric 2, ripng vlan30/fe80::214:4fff:fe6c:686d, expires in 180 secs 3333::/112, metric 2, ripng vlan30/fe80::214:4fff:fe6c:686d, expires in 180 secs 3333::/112, metric 1, local vlan30/::, expires in 180 secs 4444::/112, metric 2, ripng vlan40/fe80::214:4fff:fe6c:630f, expires in 180 secs 4444::/112, metric 1, local vlan40/::, expires in 180 secs 5555::/112, metric 1, local vlan50/::, expires in 180 secs 6666::/112, metric 2, ripng vlan40/fe80::214:4fff:fe6c:630f, expires in 180 secs
Poison Reverse is on
Interface:
vlan50
vlan40
vlan30
Redistribution:
Connected,Routes Redistribution is enabled.
SEFOS 1 SEFOS# show ipv6 route
IPv6 Routing Table - 8 entries
Codes : C - Connected, S - StaticSEFOS 1 SEFOS# show ipv6 route summary
O - OSPF, R - RIP, B - BGPIPv6 Routing Table Summary - 8 entries 3 Connected, 0 Static, 5 RIP, 0 BGP, 0 OSPF Number of prefixes: /112: 8
R 1111::/112 [2/120]
via fe80::214:4fff:fe6c:630f, vlan40
R 2222::/112 [2/120]
via fe80::214:4fff:fe6c:686d, vlan30
C 3333::/112 [1/1]
via ::, vlan30
R 3333::/112 [2/120]
C 4444::/112 [1/1]
via ::, vlan40
R 4444::/112 [2/120]
C 5555::/112 [1/1]
via ::, vlan50
R 6666::/112 [2/120]
- Review the RIP route on SEFOS2.
SEFOS 2 SEFOS# show ipv6 rip
Updates every 30 seconds; expire after 180SEFOS 2 SEFOS# show ipv6 rip database
Garbage Collect after 120 secondsRIP local RIB 1111::/112, metric 1, local vlan10/::, expires in 180 secs 2222::/112, metric 3, ripng vlan40/fe80::221:28ff:fe56:d7a9, expires in 180 secs 3333::/112, metric 2, ripng vlan40/fe80::221:28ff:fe56:d7a9, expires in 180 secs 4444::/112, metric 1, local vlan40/::, expires in 180 secs 5555::/112, metric 2, ripng vlan40/fe80::221:28ff:fe56:d7a9, expires in 180 secs 6666::/112, metric 1, local vlan10/::, expires in 180 secs
Interface:
vlan40
vlan10
Redistribution:
SEFOS 2 SEFOS# show ipv6 route
IPv6 Routing Table - 6 entries
Codes : C - Connected, S - StaticSEFOS 2 SEFOS# show ipv6 route summary
O - OSPF, R - RIP, B - BGPIPv6 Routing Table Summary - 6 entries 3 Connected, 0 Static, 3 RIP, 0 BGP, 0 OSPF Number of prefixes: /112: 6
C 1111::/112 [1/1]
via ::, vlan10
R 2222::/112 [3/120]
via fe80::221:28ff:fe56:d7a9, vlan40
C 4444::/112 [1/1]
via ::, vlan40
R 5555::/112 [2/120]
C 6666::/112 [1/1]
via ::, vlan10
- Review the RIP route on SEFOS3.
SEFOS 3 SEFOS# show ipv6 rip
Updates every 30 seconds; expire after 180SEFOS 3 SEFOS# show ipv6 rip database
Garbage Collect after 120 secondsRIP local RIB 1111::/112, metric 3, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs 2222::/112, metric 1, local vlan20/::, expires in 180 secs 3333::/112, metric 2, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs 3333::/112, metric 1, local vlan30/::, expires in 180 secs 4444::/112, metric 2, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs 5555::/112, metric 2, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs 6666::/112, metric 3, ripng vlan30/fe80::221:28ff:fe56:d7a9, expires in 180 secs
Interface:
vlan20
vlan30
Redistribution:
SEFOS 3 SEFOS# show ipv6 route
IPv6 Routing Table - 7 entries
Codes : C - Connected, S - StaticSEFOS 3 SEFOS# show ipv6 route summary
O - OSPF, R - RIP, B - BGPIPv6 Routing Table Summary - 7 entries 2 Connected, 0 Static, 5 RIP, 0 BGP, 0 OSPF Number of prefixes: /112: 7
R 1111::/112 [3/120]
via fe80::221:28ff:fe56:d7a9, vlan30
C 2222::/112 [1/1]
via ::, vlan20
C 3333::/112 [1/1]
via ::, vlan30
R 6666::/112 [3/120]
