Go to main content
Oracle® Server X6-2L Installation Guide for Windows Server Operating Systems
Exit Print View
Updated: September 2016
Before You Begin
Ensure that the following requirements are met:
  • If you want to configure RAID (redundant array of independent disks) on the server's storage drives, you must do so before you install the operating system. For instructions for configuring RAID, refer to Configuring Storage Drives for Operating System Installation in Oracle Server X6-2L Installation Guide.
    Note -  If you are using the Oracle Storage 12 Gb/s SAS PCIe RAID HBA Internal to manage your storage drives, you must create a RAID volume and make it bootable before installing the operating system; otherwise, the HBA will not be able to identify the server's storage drives.
  • Select and set up the console display option prior to performing the installation. For more information, see Selecting the Console Display Option.
  • Verify that the UEFI firmware settings are set to the optimal defaults. For instructions on how to verify and, if necessary, set the UEFI firmware settings, see Verify the UEFI Optimal Defaults.
  • Set the UEFI firmware to the desired boot mode, Legacy BIOS or UEFI. For instructions on how to set the UEFI boot mode, see Set the Boot Mode.
  • Select and set up the boot media option prior to performing the installation. For more information, see Selecting the Boot Media Option.
  • Select and set up the storage drive to be used as the installation target option prior to performing the installation. For more information, see Selecting the Installation Target.
  • Gather the Microsoft Windows Server Windows Server 2012 R2 operating system documentation so that you can use it in conjunction with the Windows Server operating system instructions provided in this section. You can obtain a copy of Microsoft Windows Server 2012 and 2012 R2 installation documentation at:
    http://technet.microsoft.com/en-us/windowsserver/default.aspx.
