Name |
Type the name of the form. |
Contacts |
Version |
Type the version number of the form. |
1 |
Inactive |
Select this check box to make the form inactive. |
None |
Description |
Type a description of the form. |
None |
Integration Object |
Select the source object for the integration object. |
Contact |
Request |
Select this check box to retrieve the document from the server during the next synchronization session. (Siebel Remote only) |
None |
Update |
Select this check box to automatically update your copy of the file when the original file is updated. |
None |
Business Object |
Displays the business object associated with the integration object you selected. |
Contact |
File Name |
Select the filename of the PDF form. |
Sample_Contact.pdf |
File Type |
Displays the file type of the PDF form. |
PDF |
Type |
Select PDF as the file type in which the form is generated. |
PDF |
Attachment Business Component |
Select the business component with an Attachments view to which you want to attach the generated form. |
Contact |
Forms Adapter |
Select Forms Integration PDF Adapter Service. Use the Debug Forms Integration PDF Adapter to troubleshoot issues with the Adobe integration. |
Forms Integration PDF Adapter Service. |
File Adapter |
Select Forms Integration File Adapter Service. |
Forms Integration File Adapter Service |
Attachment View |
Select the view to appear after the form is generated. |
Contact Attachment view |
Search Specification |
Type a search specification to select particular information from the child business component of the integration object. To include information from a Contact account only if the account is active, enter the example value in the Search Specification field, where Contact_Account represents the Integration Component Name. |
"[Contact_Account.Account Status] = 'Active' " |
