Siebel Applications Administration Guide > Adobe Forms Integration > Generating a Form from a Record (End User)Users can generate a PDF document that is automatically populated with data from a record in a Siebel application, such as a contact. The PDF file is stored in the Attachments view associated with the record. To generate a form with data from a record
Generating Forms for Multiple RecordsTo generate forms from multiple records such as contacts, perform the same procedure as for a single record, except select multiple records. When you generate multiple forms, consider the complexity of the form and the number to be generated. If the form is relatively simple, then you can typically generate 200 forms at one time without an impact to performance. If the form is complex, then generate the forms in batches of no more than 100 forms. For example, for a Citizenship Ceremony, assess the complexity of the form before you decide whether to generate forms in one procedure or in batches. |
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
