Siebel Applications Administration Guide > Assessments >
Creating an Assessment Template
You use the Sales Assessment Templates view of the Administration - Data screen to create assessment templates. This task is a step in Process of Administering and Using Assessments. To create an assessment template
- Navigate to the Administration - Data screen, then the Sales Assessment Templates view.
- In the Assessment Templates list, create a new record, and complete the necessary fields.
Some fields are described in the following table.
Assessment |
Type the name of the template. |
Type |
Select a value that specifies where you want the template to be available. For example, select Contact if you want to use this template to create an assessment plan for contacts. The choices in this drop-down list are configured by using the TEMPLATE_OBJECT_TYPE type in the List of Values. For more information, see Working with Lists of Values. |
Sales Stages |
If you are creating a template of type Opportunity, then select sales stages with which you want to associate the assessment template. When one of these sales stages (and matching sales method) is specified for an opportunity, the assessment template is used to automatically populate the Assessments view for that opportunity. |
Sales Method |
Displays a value when a sales stage is selected. |
Active |
Select the check box to display the template name in the list of values for the Template Name field of the template type. For example, if the Type field is Contact, then select this check box to display the template name in the list of values for the Template Name field in the Assessments view of the Contacts screen. |
- In the Assessment Attributes list, create a new record for each attribute you want to assess.
Order |
Type a number for the attribute's position in the Assessment Attributes list. |
Name |
Type the name of the attribute. |
Weight |
Type a number for the relative importance of the attribute. |
Max Child |
Displays the maximum score from the Attribute Values list. |
Weight Times Score |
Displays the product of the Weight and the Max Child values. |
- For each assessment attribute, create a record for each possible value of the attribute in the Attribute Values list.
Order |
Type a number for the value's position in the Attribute Values list. |
Value |
Type the name of the value, for example, Excellent, Good, or Average. |
Score |
Type the number of points that the value represents. |
Description |
Type additional information about the value to help the assessor. |
These values appear in the Pick Attribute Value dialog box when the user applies the template. For information about using an assessment template, see Assessing an Opportunity.
How Assessment Scores Are Calculated
The total score for the assessment is determined by summing weighted scores for each assessment attribute as shown in the following equation:
where: n is the number of assessment attributes in the template. The score is also calculated as a percentage of the maximum score possible as shown in the following equation:
where: Max_Scorei is the largest score for any value in the Attribute Values list for the ith attribute. This value is the Max Child value shown in the Assessment Attributes applet. For example, the largest score for Attribute 2 is 6 and the largest score for Attribute 3 is 10 in the assessment example in the Scenario for Using and Administering Assessments.
