Siebel Applications Administration Guide > Assessments > Performing an Assessment (End User)You can perform assessments of accounts, contacts, and opportunities. You can use account assessments to compare accounts, to compare accounts with a model, or to determine the information that is present or not present for an account. You complete the assessment by selecting the appropriate values for the different accounts. The following procedure shows how to assess an opportunity, but the procedure is essentially the same for any screen where assessments can be performed. An opportunity assessment helps you qualify opportunities and verify resource allocation. Using an assessment template, you can select values and attributes to assign a composite value to the opportunity. NOTE: In some companies, your Siebel application automatically generates assessments, but if this process has not been automated, then you can manually create assessments. This task is a step in Process of Administering and Using Assessments.
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
