Siebel Applications Administration Guide > Siebel Audit Trail >
Specifying Parent-Child Associations for Audit
In Siebel Business Applications, parent-child associations are set through:
- MVG (multi-value group) fields
- Parent-child applets
Siebel Audit Trail can keep track of changes in parent-child associations. For example, you can audit the association (and dissociation) of contacts with accounts. This task is a step in Process of Configuring and Using Siebel Audit Trail. To configure business components for auditing of parent-child associations
- Determine the name of the child business component with the association that you want to audit.
- Navigate to the Administration - Audit Trail screen.
- In the Audit Trail Buscomp list, perform one of the following steps:
- Select an existing record for the parent business component.
- Create a new record for the parent business component, and complete the necessary fields. Some fields are described in table in Step 2.
- Make sure that the Assoc field is checked.
- Navigate to the Child Buscomp view.
- In the Child Buscomp list, create a new record for the child business component that has an association with the parent business component you want to audit.
NOTE: If the Deep Delete user property is configured for the child business component, then create a new record for the child business component in the Audit Trail Buscomp list in the same way that you create a new record for a parent business component. In this case, do not create a new record for the child business component in the Child Buscomp list.
Some of the fields are described in the following table.
Link Name |
Select the link between the parent and child business components that you want to audit. |
Child Buscomp |
Displays the child business component for the link. |
Parent Field |
Displays the parent field of the child business component. |
Inter Child Column |
Displays the name of the child column. |
Table Name |
Displays the name of the table on which the link is based. |
M/M |
Displays whether the link is a many-to-many link. |
