Siebel Applications Administration Guide > Siebel Audit Trail > Specifying Siebel Audit Trail RestrictionsYou can restrict who gets audited by user, position, or responsibility. For example, if you set the Restriction Type to User on the Audit Trail Buscomp Fields view, then navigate to the Audit Trail Users View and add the users to audit. Restriction by responsibility or position works in the same way. This task is a step in Process of Configuring and Using Siebel Audit Trail. To specify Siebel Audit Trail restrictions
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
