Siebel Applications Administration Guide > D&B Integration > Integrating D&B Data > Running the Siebel Update Server ComponentsYou can run the Siebel update server components in the following ways: NOTE: If you have just installed the Siebel Server or if you have made changes to the Siebel Name Server, then you must synchronize before running the Siebel update server component. For more information about synchronizing server components, see Siebel System Administration Guide. TIP: If you are going to run the D&B Update Mgr (Multi-task) component, then make sure that the maximum number of tasks (MaxTasks parameter) is set correctly to accommodate the number of tasks that you specified in the dnbtask.cfg file. For information about MaxTasks, see Siebel System Administration Guide. Make sure that the D&B Update Manager (D&B) process is complete before you start the D&B Update Manager (Siebel) process. For general information about using Siebel Server Manager, see Siebel System Administration Guide. Running the D&B Update Manager Server Component From Within Your Siebel Application (Single Task Process)Complete the following procedure to run the D&B Update Manager (D&B) server component from within your Siebel application (single task process). For information about running server components, see Siebel System Administration Guide. To run the D&B Update Manager (D&B) server component from within your Siebel application (single task process)
Running the D&B Update Manager Server Component From Within Your Siebel Application (Multiple Task Process)Complete the following procedure to run the D&B Update Manager (D&B) server component from within your Siebel application (multiple task process). To run the D&B Update Manager (D&B) server component from within your Siebel application (multiple task process)
Running the D&B Update Manager Server Component From Within Your Siebel Application (Single Task Process)Complete the following procedure to run the D&B Update Manager (Siebel) server component from within your Siebel application (single task process). To run the D&B Update Manager (Siebel) server component from within your Siebel application (single task process)
Running the D&B Update Manager Server Component From Within Your Siebel Application (Multiple Task Process)Complete the following procedure to run the D&B Update Manager (Siebel) server component from within your Siebel application (multiple task process). To run the D&B Update Manager (Siebel) server component from within your Siebel application (multiple task process)
Running the D&B Update Manager Server Component From a Command Line (Single or Multiple Task Process)Complete the following procedure to run the D&B Update Manager (D&B) server component from a command line (single or multiple task process). To run the D&B Update Manager (D&B) server component from a command line (single or multiple task process)
Running the D&B Update Manager Server Component From a Command Line (Single or Multiple Task Process)Complete the following procedure to run the D&B Update Manager (Siebel) server component from a command line (single or multiple task process). To run the D&B Update Manager (Siebel) server component from a command line (single or multiple task process)
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
