Siebel Applications Administration Guide > D&B Integration >
Setting Up the Symbolic URL for Access to the D&B Database
When you have a connection to the Internet and have a D&B account set up already (with a user ID and password), you can:
- Obtain the most current account information by invoking real-time searches of the D&B database and online purchase.
- Access and order D&B business and credit reports.
To access D&B data live from your Siebel application through the D&B Web site, you must first contact D&B for a user ID, password, and payment options. Then you can set up your Siebel application to access the D&B database. For more information about D&B reports and about searching D&B for new accounts, see Accessing Company Data and Reports with D&B. To set up the symbolic URL for D&B real-time search and update
- Navigate to the Administration - Integration screen, then the WI Symbolic URL List.
- From the visibility filter, select Symbolic URL Administration.
- In the Symbolic URL list, select DNBGlobalAccess.
- Make sure the URL is as follows:
https://globalaccess.dnb.com/access/scripts/broker.asp
- In the Symbolic URL Arguments list:
- Select the USERID record, and enter the user ID provided by D&B in the Argument Value field.
NOTE: This field is not case-sensitive.
- Select the USERPASS record, and enter the password provided by D&B in the Argument Value field.
Setting Up the Symbolic URL for D&B Report Ordering
Complete the following procedure to set up the symbolic URL for D&B report ordering. If you are using Siebel eBriefings and want to enable a link from briefing documents to the D&B report ordering site, then see Siebel Briefings Administration Guide. To set up the symbolic URL for D&B report ordering
- In the Symbolic URL list, select DNBReport.
- Make sure that the Host Name is www.dnb.com and that the URL is as follows:
https://reportserver/scripts/ProductRetriever
- Select the USERPSWD record, and enter the password provided by D&B in the Argument Value field.
- From the visibility filter, select Host Administration.
- In the list of HTTP hosts, make sure that there is a record where Name is www.dnb.com and Virtual Name is reportserver.
