| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Applications Administration Guide > D&B Integration > Configuring D&B IntegrationTable 75 provides general guidance about configuration.
 Specific configuration topics include:
 TIP: When debugging in your test environment, increase the event log level to 4 to see more details in the log file. However, it is strongly recommended that you set the level to 1 (the default) when you run in a production environment to prevent the log file from overflowing. For information about event logging, see Siebel System Monitoring and Diagnostics Guide. Update Server Process ConfigurationThe D&B update server processes use the Batch Real-Time Integration (RTI) technology and the RTI configuration files (dnbmaps.sql for single task and dnbmaps.tsq for multiple tasks). You can edit the RTI configuration files to suit your business requirements. The general syntax of the RTI maps specified in the configuration files is as follows: UPDATE_SOME_TABLE.MOD1TABLE = [Target Table to update] UPDATE_SOME_TABLE.MOD1WHERE = [A WHERE clause] UPDATE_SOME_TABLE.MOD1INSERT = [TRUE/FALSE] UPDATE_SOME_TABLE.MOD1UPDATE = [TRUE/FALSE] UPDATE_SOME_TABLE.MOD1DELETE = [TRUE/FALSE] UPDATE_SOME_TABLE.MOD1SQL = [A Valid SQL Query] The RTI configuration files are located in the  Use caution when making changes to these RTI configuration files. It is recommended that you engage a qualified professional for your customization process. CAUTION: Do not change the default DELETE setting in the existing UPDATE* sections. Do not set DELETE to TRUE. If your business need necessitates deleting rows in the target table as part of the D&B Update Manager process, then you can request help by creating a service request (SR) on My Oracle Support. Account Promotion and Prospect List Creation ConfigurationYou can select specific fields that are populated by the D&B promotion to a Siebel account or by the D&B list-creation process. These fields are controlled by maps in the business component user properties within the DNB Account and DNB Contact business components. These maps are listed in Table 81. Using Siebel Tools, you can change, add, or delete source and destination field mapping. See the map descriptions in Table 81 to determine the map to use for a set of source and destination fields. Use caution when making changes to these maps. It is recommended that you engage a qualified professional for your customization process. CAUTION: Although the delete capability is available, it is recommended that you deactivate unwanted map entries instead of deleting them. This approach is safer and can be accomplished by checking or clicking the deactivate column for the unwanted entry. You can create an entry using the following syntax: Name Column: [MAP NAME]: [DESTINATION FIELD] Value Column: [D&B SOURCE FIELD] NOTE: Each map works only with a specific Destination Business Component and a specific Source Business Component. Running the D&B Update Manager (D&B) Process Without Updating or Deleting Existing DataDepending on your business process, you might want to run the D&B Update Manager (D&B) server component without updating or deleting any existing data in the S_DNB_ORG table. You edit the RTI configuration file to perform this task. To edit the RTI configuration file so that existing data in the S_DNB_ORG table is not updated or deleted
 Running the D&B Update Manager (Siebel) Process Without Updating Account NameYou might want to run the D&B Update Manager (Siebel) server component without updating the existing account names. You edit the RTI configuration file to perform this task. To edit the RTI configuration file so that account names are not updated
 Running the D&B Update Manager (Siebel) Process Without Updating Account Location (Single Task)You might want to run the D&B Update Manager (Siebel) server component without updating the existing account locations. You edit the RTI configuration file to perform this task. Complete the following procedure to edit the RTI configuration file so that account locations are not updated (single task). To edit the RTI configuration file so that account locations are not updated (single task)
 Running the D&B Update Manager (Siebel) Process Without Updating Account Location (Multiple Task)You might want to run the D&B Update Manager (Siebel) server component without updating the existing account locations. You edit the RTI configuration file to perform this task. Complete the following procedure to edit the RTI configuration file so that account locations are not updated (multiple task). To edit the RTI configuration file so that account locations are not updated (multiple task) |
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
