Siebel Applications Administration Guide > Getting Started > Requirements for Getting StartedAfter you successfully install your Siebel Business Applications, you are ready to set up your Siebel Business Applications. Table 3 lists the software that you must correctly install before you can begin to use your Siebel Business Applications. After you successfully install these Siebel servers and applications, you can proceed to use them. |
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
