Siebel Applications Administration Guide > Households >
Adding Contacts to a Household
Contacts are individuals associated with a household. Agents can specify one person in the household as the head of household and then identify the others as spouse, child, or dependent parent. This task is a step in Process of Managing Households. To add contacts to a household
- Navigate to the Households screen, then the List view.
- Drill down on the Name field of the household record to which to add the contacts.
- Navigate to the Contacts view.
- In the Contacts list, perform one of the following steps to specify the contact to add:
- Add an existing contact to the household, select the contact from the Add Contacts dialog box, and click OK.
- Create a new record in the Contacts list.
- Complete the necessary fields for the record.
Some of the fields are described in the following table.
Primary |
Select the check box to designate the current contact as the main decision-maker for the household. |
Income |
Type the contact's income. This value is not used to calculate the household's total income. |
Relationship |
Select the role of the contact within the household. |
Households |
Select one or more households in which the contact is a member. |
Alias |
Type the contact's nickname if you create a new contact for the household. |
Employee Flag |
Displays a check box that indicates the contact is an employee of your company. |
Specifying Addresses for Household Contacts
Complete the following procedure to specify an address for the household contact. To specify an address for the household contact
- Drill down on the Name field of a household record.
- Navigate to the Contacts view, select the contact in the Contacts list, and drill down on the Last Name field.
- Navigate to the Addresses List view, create a new record in the Address list, and complete the necessary fields.
- Click the thread bar to return to the Contacts view of the Households screen, and then scroll down to display the Contact form.
- In the Contact form, complete the following steps:
- Click the select button in the Address field to display the Contact Addresses dialog box.
- In the Contact Addresses dialog box, select the Primary check box for the contact's main address, and click OK.
- In the Contact form, complete additional fields.
Account |
Select the business or organization associated with the contact. |
Site |
Displays the site of the account associated with the contact. |
Address |
Select the contact's address or addresses. The procedure for entering the addresses to appear in this field is described in Step 4. |
Email |
Type the contact's email address. |
NOTE: In the Households screen, a contact's address is the residential or personal address. In the Contacts screen, the address in the Contact form is the address of the account associated with the contact. In the Addresses List view of the Contacts screen, you can specify a contact's other addresses. You can select household addresses only from these individual contact addresses.
