Siebel Applications Administration Guide > Configuring the Inbox > Configuring Action Buttons for Inbox ViewsIn the preconfigured Siebel application, users take action on an Inbox item by choosing from the Action drop-down list. You can configure the Inbox so that the first five values in the Action drop-down list appear as buttons on the UInbox Item Task List Applet. Activating the Inbox Action ButtonsWhich controls you activate depends on whether your Siebel application runs in standard-interactivity mode or in high-interactivity mode. For more information about working with controls in applets, see the topic about editing applet layout in Configuring Siebel Business Applications. Configuring Action Buttons for Standard InteractivityComplete the following procedure to configure action buttons for standard interactivity. To configure action buttons for standard interactivity
Configuring Action Buttons for High InteractivityComplete the following procedure to configure action buttons for high interactivity. To configure the action buttons for high interactivity
Configuring Background Colors for the Inbox Action ButtonsIf you edited the cascading style sheet for the list applet and changed the background colors, then edit the background colors for the action buttons so that they match the applet. |
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
