Siebel Applications Administration Guide > Configuring the Inbox >
Configuring the Category Icon for the Inbox
You can change and add to the icons that appear in the Category field by editing the Inbox Category bitmap category. For more information about bitmap categories and working with images, see Configuring Siebel Business Applications. To add Category icon for a Category field value
- Add the icon image file, in Graphic Interchange Format (GIF), to the
images directory.
Base the size of your image on the existing Category icons in this directory, for example, icon_approval.gif.
- In Siebel Tools, create a bitmap record for the Inbox Category bitmap category object, and complete the fields in the following table.
Name |
Type the language-independent code for the value, from the UINBOX_INBOX_TYPE LOV, for example, CAMPAIGNS. |
Bitmap |
Type the name of the file from Step 1. |
