Siebel Applications Administration Guide > Configuring the Inbox > Universal Inbox Business Service Methods >
GetInboxItemInfo Method
This method returns field values from an Inbox item and, if GetParams is true, then returns the name-value pairs for the Inbox item. The method searches as follows:
- InboxItemId
- ObjectId + InboxTypeName
Input Arguments
Table 35 lists the input arguments for this method.
Table 35. GetInboxItemInfo Method, Property Set
InboxItemId |
No |
This property is the row ID of the Inbox item. The ID is not updated, but is used for searching. |
ObjectId |
No |
This property is the object ID of the Inbox item. It is not updated, but is used for searching. |
InboxTypeName |
No |
This property is the name of Inbox type. It is not updated, but is used for searching. |
GetParams |
No |
This property returns all name-value pairs if the value is Y. |
Output Arguments
Table 36 lists the output arguments for this method.
Table 36. GetInboxItemInfo Method, Property Set
ObjectId |
This property is the object ID of the Inbox item. |
InboxTypeId |
This property is the ID for the Inbox type. |
InboxTypeName |
This property is the name of Inbox type. |
InboxName |
This property is the name for the Inbox. |
InboxPartyId |
This property is the party ID of the Inbox owner. |
Comments |
None. |
InboxUTCExpirationTS |
This property is the UTC timestamp. |
Name - value pairs |
None. |
