Siebel Applications Administration Guide > Configuring the Inbox > Universal Inbox Business Service Methods >
GetInboxOwnerInfoEx Method
This method returns field values for an Inbox item owner. If the Inbox item owner is in the screen-active business component record, then the method returns the values from the screen-active business component. The method searches as follows:
- OwnerInfoId
- InboxItemId, OwnerPartyId
- ObjectId, InboxTypeName, OwnerPartyId
Input Arguments
Table 39 lists the input arguments for this method.
Table 39. GetInboxOwnerInfoEx Method, Property Set
ObjectId |
No |
This property is the object ID of the Inbox item. It is not updated, but is used for searching. |
InboxTypeName |
No |
This property is the name of Inbox type. It is not updated, but is used for searching. |
OwnerPartyId |
No |
This property is the party ID for the Inbox owner. It is not updated, but is used for searching. |
InboxItemId |
No |
This property is the row ID of the Inbox item. It is not updated, but is used for searching. |
OwnerInfoId |
No |
This property is the information ID for Inbox owner. It is not updated, but is used for searching. |
Output Arguments
Table 40 lists the output arguments for this method.
Table 40. GetInboxOwnerInfoEx Method, Property Set
OwnerInfoId |
This property is the information ID for Inbox owner. |
OwnerPriority |
This property is the owner priority for the Inbox item task. |
OwnerActionLIC |
This property is the language-independent code. |
OwnerUTCDueTS |
This property is the UTC timestamp. |
OwnerComments |
None. |
OwnerStartWorkingTime |
This property is the owner start working time for the Inbox item task. |
OwnerEndWorkingTime |
This property is the owner end working time for the Inbox item task. |
