Siebel Applications Administration Guide > Configuring the Inbox > Universal Inbox Business Service Methods >
UpdateInboxItemInfo Method
This method updates field values for an Inbox item. The name-value pairs are put into the Inbox Parameters table. The method searches as follows:
- InboxItemId
- ObjectId + InboxTypeName
Input Arguments
Table 45 lists the input arguments for this method.
Table 45. UpdateInboxItemInfo Method, Property Set
InboxItemId |
No |
This property is the row ID of the Inbox item. It is not updated, but is used for searching. |
ObjectId |
No |
This property is the object ID of the Inbox item. It is not updated, but is used for searching. |
InboxTypeName |
No |
This property is the name of Inbox type. It is not updated, but is used for searching. |
InboxName |
No |
This property is the name of the Inbox. The value passed cannot be empty. |
InboxPartyId |
No |
This property is the party ID of the Inbox owner. The value passed cannot be empty. |
ReplicationLevel |
No |
This property indicates whether this Inbox item must be routed when using remote mobile client. Select one of the following options:
- All. Indicates HQ, Regional, Local.
- Regional. Indicates HQ, Regional.
- None. Indicates HQ.
Comments |
No |
None. |
InboxExpirationDuration |
No |
The duration is expressed in seconds. The value passed cannot be empty. |
InboxUTCExpirationTS |
No |
This property is the UTC timestamp. The value passed cannot be empty. |
