Siebel Applications Administration Guide > Configuring the Inbox > Examples of Inbox TriggersThis topic includes the following samples of Inbox triggers:
About the Sample WorkflowsThe following pages describe three sample workflows that apply to service requests and that illustrate the use of the Inbox. You can use Siebel Tools to import the workflow files into the Siebel Sample Database, and try out the workflows. Additionally, you can import them into your own implementation and modify them for your business needs. Where to Find the Sample Workflow FilesThese sample workflows are provided as part of the sample database installation. You can find these workflow files in the The names of the files that contain the sample workflows are: Creating Inbox Types for Use with the Sample WorkflowsIf you want to try out the sample workflows in the Sample Database, then you must create the SRManager and SROwner Inbox types. To create two Inbox types for use with the sample workflows
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
