Siebel Applications Administration Guide > Configuring the Inbox >
Setting Up Inbox Actions
Review the information in the following topics before setting up Inbox actions:
This task is a step in Process of Setting Up and Configuring Inbox. About Actions
There are several circumstances where a business service method can be invoked to act on an Inbox item. A different action type is used for each. Table 16 summarizes these actions.
Table 16. Actions for Inbox Types
Invokes the Specified Business Service Method When... |
Action Field Dropdown |
The user takes action (edits the Action field on the Inbox item). |
Name Drilldown |
The user drills down on the Name field of the item. You can also use the Views view to configure this hyperlink. For more information about how to use the Views view to configure this hyperlink, see Setting Up Inbox Links to Views and SmartScripts. |
Local Validation |
The user, in a remote database, drills down on the Name field of the item. For more information, see Configuring the Inbox for Use with Remote Databases. |
Initialize |
Do not use this action unless you are upgrading. This action is provided for backward compatibility. For more information, see Siebel Database Upgrade Guide. This action invokes the Initialize method of the Universal Business Service. It creates an Inbox item and starts the defined method. |
Transfer |
The user transfers the Inbox item to another user. |
Transfer Validation |
The user transfers the Inbox item to another user, and the Transferable field for the Inbox Type is selected. In the preconfigured Siebel application, the Transfer action and Transfer Validation action are implemented only for task inbox items (the Task business object). These actions invoke the Transfer method of the Task Administration business service. If you want to implement these actions for another inbox item, then you must create for the appropriate business object a custom method in a business service or a custom workflow process to perform the action, and then set up the action to invoke this custom method or workflow. |
About Deactivate Item Upon Finish and Deactivate Owners Upon Finish Fields
An Inbox item can be deactivated in the following ways:
To set up an Inbox action
- Navigate to the Administration - Inbox screen, then the All Inbox Types view.
- In the Inbox Types list, select the Inbox Type, and navigate to the Actions view.
- In the Actions list, create a new record, and complete the necessary fields.
Some fields are described in the following table.
Action |
Select a value for the action. For more information, see Table 16. |
Business Service |
Select the business service to use, for example, Workflow Process Manager. |
Business Service Method |
Select the method to invoke for the selected business service. |
Business Service Method Arguments |
Type the arguments required to invoke the business service method. For example, if you use the Workflow Process Manager business service, then your workflow must contain the properties with the same argument names. |
Deactivate Item Upon Finish |
Select the check box to deactivate the Inbox item for all owners, after the method has successfully completed. |
In addition to the arguments passed in the Business Service Method Arguments field, the arguments in the following table are always passed to your custom business service or workflow.
ActionLIC |
The value the user selected from the Action field. For example, if the Inbox Type has an Action Type of UINBOX_STATUS_TYPE, then the value of this argument is one of the following: Accepted, Received, or Rejected. |
BusinessObjectName |
The value of the business object name field for the Inbox type. |
Employee Login |
The login ID of the user who uses the Inbox type. |
InboxItemId |
The row ID of the Inbox item. This argument refers to the UInbox Item business component, which is used by the Submitted Items List view. |
InboxTypeId |
The row ID of the Inbox type. |
InboxTypeName |
The name of the Inbox type. |
IntegrationObjectName |
The value of the integration about name for the Inbox type. If the Inbox type has an integration object name, then the value of this field is passed in this argument. |
ObjectId |
The row ID of the business object name that is managed by the Inbox type. NOTE: This row ID is not the standard Object ID property that is available on every workflow.
OwnerInfoId |
The row ID of the Inbox Item Task. This argument refers to the UInbox Item Task business component, which is used by the Inbox Items List and Completed Items List view. |
NOTE: The Inbox Action passes the row ID of the feature object in ObjectId. Within a workflow process, the ID of the primary business component on which the process is based must be stored in the process properties Object ID. Note the space character in the Object ID process property name. Therefore, the workflow process first copies the content of ObjectId to Object ID, if necessary.
