Siebel Applications Administration Guide > Initial Setup >
Setting Up Satmetrix Survey Reports
NOTE: This topic applies only to those who have purchased Siebel Satmetrix Surveys or who have purchased surveys directly from Satmetrix Systems.
To view Satmetrix survey reports through your Siebel application, you must:
- Add the Account Satmetrix Survey View view to the appropriate user responsibilities. For information about how to add views to responsibilities, see Siebel Security Guide.
- Enter the secret key string provided by Satmetrix Systems into the Satmetrix Key Value system preference. For information about how to change system preferences, see Setting System Preferences.
- Complete the procedures in this topic.
Extending the List of Values
Extend the List of Values for WI_ARG_TYPE. This LOV defines the arguments for integrating with other portal and internet applications. For more information about creating records for Lists of Values, see Working with Lists of Values. To extend the List of Values for WI_ARG_TYPE
- Navigate to the Administration - Data screen, then the List of Values view.
- Create a new record, and complete the fields, using the following table as a guide.
Type |
WI_ARG_TYPE |
Display Value |
Satmetrix |
Language-Independent Code |
Satmetrix |
Active |
Yes |
Translate |
Yes |
Replication Level |
All |
Setting Up the Symbolic URL
Next, set up the symbolic URL for access to the Satmetrix reports server. For more information about symbolic URLs, see Siebel Portal Framework Guide. To set up the symbolic URL for access to Satmetrix Reports
- Navigate to the Administration - Integration screen, then the WI Symbolic URL List view.
- From the visibility filter, select Symbolic URL Administration.
- In the list of symbolic URLs, select SatmetrixSurvey.
- Make sure the URL is the URL for the reports server provided by Satmetrix Systems.
- In the Symbolic URL Arguments list, complete the fields, using the following table as a guide.
EncodeUrl |
Yes |
Command |
FALSE |
Yes |
1 |
version |
Yes |
Constant |
Obtain from Satmetrix |
Yes |
2 |
windowsize |
Yes |
Command |
WebControl width=1000 height=500 border=1 |
Yes |
3 |
type |
Yes |
Constant |
acct |
Yes |
4 |
acctid |
Yes |
Field |
Id |
Yes |
5 |
acctname |
Yes |
Field |
Name |
Yes |
6 |
contactid |
Yes |
Constant |
Yes |
7 |
contactname |
Yes |
Constant |
Yes |
8 |
user |
Yes |
Profile Attribute |
Login Name |
Yes |
9 |
domain |
Yes |
Constant |
Yes |
10 |
model |
Yes |
Constant |
Yes |
11 |
created |
Yes |
Field |
Timestamp |
Yes |
12 |
token |
No |
Satmetrix |
Satmetrix Surveys, CalculateToken |
Yes |
13 |
