Siebel Applications Administration Guide > Ongoing Application Administration Tasks >
Setting System Preferences
System preferences control how Siebel Business Applications operate in your environment. Review default settings and modify these settings as appropriate for your environment. For a list of the system preferences in Siebel Business Applications, see System Preferences. Some system preferences might not take effect until the affected components are restarted. For information about shutting down and starting Siebel Server components such as a Siebel Application Object Manager, see Siebel System Administration Guide. To set system preferences
- Navigate to the Administration - Application screen, then the System Preferences view.
- Check that the default system preference values are correct in your environment.
- Change values for system preferences as needed.
