| Siebel Applications Administration Guide > Ongoing Application Administration Tasks >  Setting Up Predefined Queries
 To set up predefined queries, review the following topics: About Setting Up Predefined QueriesPredefined queries (PDQ) automate queries that a user can perform online. Rather than creating a query, entering criteria, and running the query, the user selects a PDQ from the Queries drop-down list.  Predefined queries can be private (available only to the person who created them) or they can be public (available to all the users of the Siebel application). Set up predefined queries in the following ways:
Create and execute a query in the usual way, and then save the query.
Create or modify a predefined query in the Predefined Query screen.
 Guidelines for Setting Up QueriesWhen setting up queries, remember: Creating Predefined QueriesThe following procedure describes how to create a predefined query by saving a query. To create a predefined query by saving a query
Navigate to the screen where you want to run the query.
Create and execute a query.
From the application-level menu, select Query, then Save Query As.
In the Save Query As dialog box, enter a name for the query.
The query is added to your list of predefined queries. This query is private, and only you can view it.If you want to make the query public, then perform the following steps:
Navigate to the Administration - Application screen, then the Predefined Queries view.
In the Predefined Queries list, deselect the Private field in the record for the query you just created.
 Setting Up Queries in the Predefined Query ViewThe following procedure describes how to set up a query in the Predefined Query view. To set up a predefined query in the Predefined Query view
In the Predefined Queries list, create a new record, and complete the necessary fields.
Some fields are described in the following table.
    | Object | Select the object on which the query is performed.  |
    | Name | Type the name that appears in the predefined query drop-down list. |
    | Private | Select the check box to indicate the query is available only to the person who created it.  When you clear the check box y to make a query public, the other users must first exit the Siebel application and reenter before they can see the newly public query. |
    | Query | Type the SQL code for the query.  When you create a query for a field that is a multi-value group, you can use the EXISTS operator to query nonprimary child records. For more information about the syntax, see information about operators, expressions, and conditions in Siebel Developer's Reference. NOTE:  You cannot use SQL functions in the query for a predefined query. |
    | Cache Result | Select the check box to indicate the query returns all rows up to the value of the DSMaxFetchArraySize parameter set for the data source. For information about setting DSMaxFetchArraySize, see information about modifying Named Subsystems in Siebel System Administration Guide. NOTE:  Setting DSMaxFetchArraySize to -1 and Cache Result to Y can cause memory problems for queries returning many rows. |  |
