| Siebel Applications Administration Guide > Signature Capture > Process of Creating an Applet for Signature Capture > Creating a Hidden Control on the Applet
 You must create a hidden control on the applet, and set the Field property for the control. This task is a step in Process of Creating an Applet for Signature Capture. To create a hidden control
In Siebel Tools, right-click the applet object you created in Creating a Form Applet.
Select Edit Web Layout.
Drag the Hidden control from the Palettes window to the applet canvas.
Set the Field property of the control to the name of the field that you created in Extending the Siebel Database for a Signature Capture Control.
For example, set the Field property of the control to AA Signature. NOTE:  This setting enables the browser script to access the field when the script sets and clears the controls. Select File, then Save.
