| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Applications Administration Guide > Signature Capture > Process of Creating an Applet for Signature Capture > Adding the Applet to an ObjectYou must add the applet that you have developed to an object to which you want to add the signature capture control. You can add an applet with a signature capture control to the following objects: This task is a step in Process of Creating an Applet for Signature Capture. To add the applet to an object
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
