Siebel Applications Administration Guide > Global Target List Management > Creating Target Lists by Querying (End User)The most usual way to create a target list is by querying and then saving to a target list some or all of the party records returned by the query. The records that you save can be the records that are returned by the query. For example, if you query contacts, then you can save the contact records to a target list. The records that you save can also be the records that are associated with the records that are returned by the query. For example, if you query opportunities, then you can save the positions on the opportunities' sales teams to a target list. (You cannot save the opportunity records to a target list.) This task is a step in Process of Managing Global Target Lists. To create a target list by querying
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
